Can't Find Spark Plugs
Old Oct 1, 2004 | 12:25 AM
wsc842003's Avatar
Default Can't Find Spark Plugs
Hello, i'm new here. I bought a 1997 A4 1.8 L Turbo. I can't seem to find where the spark plugs are, because they need to be changed
Old Oct 1, 2004 | 01:50 AM
audiboy1618's Avatar
Default RE: Can't Find Spark Plugs
Hey wsc842003, here are some good tips to finding them. First, were going to need to pop the hood(located on the driver side towards the floor. Then, were going to need a screw driver(philips head), take off the engine cover and be amazed.
Old Oct 1, 2004 | 01:56 AM
Doose's Avatar
There is a black plastic engine cover that goes over the valve cover. Your oil fill cap is about in the middle of it. Under that plastic cap you will see four white squares with two bolts securing each one to the valve cover. Remove those and the plugs are underneath. You'll need a socket extension to reach the plugs. If you are planning on doing the replacement yourself, check the archives, there's got to be a link to a tech article with more specifics.
Old Oct 1, 2004 | 06:15 PM
david9999's Avatar
Turn off the lights and look for sparks. Spark plugs should be right above
Old Oct 1, 2004 | 08:31 PM
gregp1962's Avatar
HEY, wsc842003's question isn't as dumb as it seems. Those spark plugs are well hidden. Even after you take the plastic engine cover off, it's not obvious where they are.
skycladgod
Sep 21, 2013 12:07 PM
cwedholm1
Mar 13, 2010 11:47 PM
djblaize
Feb 8, 2009 12:42 PM
littlewood
Feb 2, 2009 10:38 PM
dhescheles
Jan 7, 2009 05:06 PM
