Idle control
Old Oct 1, 2004 | 08:43 PM
gregp1962's Avatar
Default Idle control
Sometimes, my 1.8t has a hard time idling after coming to a stop. It seems to act like the idle control valve is bad. But, in looking at it, it doesn't look like it has one. What would be the cause of this?
Old Oct 1, 2004 | 09:33 PM
Jestnomen's Avatar
6th Gear
Default RE: Idle control
I thought only the V6 had an ICV.
Things to check:
Vacuum hoses (replace them if they are looking cracked or dry).
MAF sensor
Leaks around MAF housing
Get new sparkplugs
Do a throttle body adaption
VAG your car
Old Oct 1, 2004 | 10:32 PM
David_K's Avatar
Does it do the RPM "bounce"? if so its just your computer relearning your car. its perfectly normal and will returnn to normal in a day
Old Oct 1, 2004 | 11:21 PM
Jestnomen's Avatar
6th Gear
He said "sometimes", which leads me to believe it is a cronic problem. But you are correct, the idle will bounce while the ECU is adapting (~100 miles) after a battery disconnect.
88A5TQ
Dec 2, 2009 05:33 PM
nrf1211
Oct 10, 2008 02:15 AM
motorrad
Sep 27, 2008 08:11 PM
brightside06
Sep 15, 2007 04:00 PM
GT5 S
Jan 31, 2007 01:16 PM
