Can't fuel A4
Old Sep 16, 2005 | 11:50 PM
mx250's Avatar
Default Can't fuel A4
I've got a 2003 A4 3.0, and the problem is that on occasion I can't fill it up with fuel. It takes .6 gallons, and then stops. If I push it, fuel will overflow the fill-pipe. It is always .6 gallons. If it goes further than .6, it will fill all the way. It seems to happen more often if I try to fill after driving for less than a half-hour or so.
So far the dealer has replaced the carbon cartridge for the tank vent. That seemed as if it helped some, but after a few months it is worse than before. I'm wondering if there is some kind of valve at the bottom of the fill-pipe and it is stuck and I'm just filling up the fill-pipe? I've searched and I can't find anything about this.
Any ideas, and what I should tell the shop to look for?
Thanks!
Old Sep 17, 2005 | 12:20 AM
PandaXpress's Avatar
Default RE: Can't fuel A4
this happens to me does this only happen in hot days
the gas expands and i makes back pressure which makes it hard to refuel
you should take the gas cap off and let the pressure escape a lil
Old Sep 17, 2005 | 02:43 AM
mx250's Avatar
ORIGINAL: PandaXpress
Well, I got the car last Nov, and it has happened during the winter. It didn't really do it all summer, and now it is starting up again.
Thanks for the tip though, I'll give it a try (it does sound like there is pressure in there - a hissing sound).
Old Sep 17, 2005 | 09:40 AM
david9999's Avatar
If your car is still under warranty take it back and have them fix it. After all, it is their problem until the warranty is up.
Old Sep 17, 2005 | 11:49 AM
mx250's Avatar
ORIGINAL: david9999
Yes, I have already had it "fixed" once, and I will have it "fixed" again. Since they did such a good job the first time, I was hoping this time around I could give them a little help by telling them exactly what needed to be fixed. That's why I posted here. It is a pain in the *** to be without a car, and when they don't know what is wrong it takes them longer to fix it. In the mean time, workarounds are useful, too. I still have plenty of miles and time left on the warranty.
Old Sep 17, 2005 | 10:13 PM
go to another dealer
Old Sep 19, 2005 | 12:51 AM
onepoint8tee's Avatar
ORIGINAL: mx250
Maybe your fuel gauge is reading empty when you are only 6 gallons less than full? But Im sure you would notice if you had to fill up that often.
Old Sep 19, 2005 | 01:02 AM
mx250's Avatar
ORIGINAL: onepoint8tee
Ahhh, it only takes POINT SIX gallons (less than one), not six gallons, before it stops. I regularly go around 400 miles between fill-ups. Once the gas pump shows .7+ gallons, I know I am in the clear. Thanks, though!
Old Sep 19, 2005 | 03:09 AM
fastex500's Avatar
Here is a funny explination. A friend of mine had the exact same problem with a Durango (horrors). What happened, was this: Kids thought it would be funny to stick a Tampon in the filler nozel at a gas station. When my friend filled up, it forced the tampon into his fuel filler neck, but not past the lower baffel. As it sat there it began to absorb and expand (as they are supposed to do....) and thus kept him from fueling up.
We were able to see it by opening the top valve and peering in with a flashlight (not using a match... lol). Just an idea from experience......
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
DJmart
Aug 3, 2013 11:08 AM
Luisthehomie
Oct 1, 2012 05:24 PM
sollyd25
Dec 2, 2011 07:39 AM
