Car Alignment
Old Feb 2, 2008 | 08:43 PM
dankhound's Avatar
Default RE: Car Alignment
and have them get the caster within spec.
There are no caster adjustments.
Raised toe only needs to be done if tie rods or the steering rack or spindle are replaced. In any case all you have to do is look at the gap between the bottom of the spindle and the top part of the ball joint seal. Keep that the same when replacing tie rods and the raised toe is close enough. It only affects bump steer anyway.
Old Feb 2, 2008 | 09:27 PM
pyropenguin's Avatar
ORIGINAL: dankhound
Good to know.
Old Feb 2, 2008 | 10:52 PM
Bogie's Avatar
Just so y'all know if you replace your control arms - my B5 has 2 sets of holes for the front lower control arms. Stock position was inner hole. I put them back there with the coilovers and new control arms installed. Don't put it in the wrong hole guys.
Front Lower Rear Control Arm
Front Lower Front Control Arm
kevintt
Jun 21, 2008 05:25 PM
kwaskow
May 23, 2008 06:08 PM
grrrrrrr
May 9, 2008 07:41 PM
wings7351
May 24, 2007 01:42 PM
ouTTie914
Aug 17, 2006 10:48 PM
