car hard to start after refueling
Old May 15, 2007 | 11:57 AM
mack29730's Avatar
Default car hard to start after refueling
i have a 1998 audi a4 quattro with the 2.8 motor everytime i put gas in my car it will not start i have to let the motor turn over for about a min then it will start run rough a min then it's fine until i get gas again any idea on what this could be?
Old May 15, 2007 | 12:04 PM
Cloudy Audi's Avatar
Default RE: car hard to start after refueling
My '99 burps 3 times and then runs fine, it does start right up though. I noticed this even if I don't fill it up all the way.
Old May 15, 2007 | 12:06 PM
mack29730's Avatar
same here no matter how much i put in it acts this way.
Old May 15, 2007 | 01:44 PM
x1rider's Avatar
most likely evap canister problem, I had that happen a few years ago. I could only fill up the gas tank 2 gallons at a time and the engine would have to turn over a little while before starting.
Old May 15, 2007 | 08:21 PM
david9999's Avatar
It is most likely the EVAP purge valve right behind the air filter box, or the one way check valve connected to the purge valve. The valve is about 50 dollars and it is a 10 minute DIY replacement.
rccks96
Aug 29, 2023 08:58 PM
jowing
Aug 5, 2012 05:03 PM
socaljoe
B7 Models
Dec 30, 2010 09:36 PM
neidermayer
Mar 18, 2008 12:59 PM
FOUR Os
Nov 27, 2006 10:59 PM
