98 A6 hard starting after refueling
Old Oct 8, 2006 | 11:59 AM
FOUR Os's Avatar
Default 98 A6 hard starting after refueling
We filled up again for the second time since we bought the car and have started it a bunch of times in between and it starts right up but both times we refueled it was real hard to start requiring at least 10 seconds of cranking....all other times it starts in the first crank....
Old Oct 8, 2006 | 01:44 PM
techbod's Avatar
Default RE: 98 A6 hard starting after refueling
did you leave the ignition on when filling up?? was the attempted engine start with the gas cap off, any CEL light check for fault codes
Old Oct 8, 2006 | 09:38 PM
FOUR Os's Avatar
Thanks Dave...
No the car was off and so was the ignition....I filled it up,put the gas cap back on and started it ...
The (MIL) Malfunction Indicator Light is on and the codes are,
P1136
P1138
P0455
P0441
But it starts great every time except after the refuel...in fact,the first time it did this the light was not on...
Paul
Old Oct 18, 2006 | 12:09 AM
Azzle's Avatar
Yes i have the same problem on my 2.8 a6 1998 there is no one that knowz the problem??
Old Oct 23, 2006 | 07:06 AM
a6lovely's Avatar
Member
I have the same Problems too, I have checked the front compartment for leaks but i can't find one...
I guess I will have to wait until someone solve these issues..
Let me guys know if you guys can trouble shoot it
Thanks
Old Oct 23, 2006 | 07:07 AM
a6lovely's Avatar
Member
Thanks
Old Oct 26, 2006 | 02:21 AM
dankhound's Avatar
Try pinching off the evap purge valve line going to the engine during refueling. And then start the vehicle with the line still pinched. Its the only place i can think of fuel, or fuel vapor getting to the engine causing a hard start. If the vehicle starts up right away you have a bad evap purge valve.
Old Nov 10, 2006 | 01:30 AM
Azzle's Avatar
Finally I Found out what thr problem is ....... = Carbon canister
Old Nov 10, 2006 | 06:34 AM
matt_o121's Avatar
any further details?
whats wrong with the canister?
Old Nov 27, 2006 | 10:59 PM
com2255's Avatar
had the same problem with my 99 A6 about 2 years ago. Hard starting upon refueling. I don't recall the codes the computer through but they looked similiar (leak in evap, lean on one of the banks etc). I ended up replacing the purge value, this solved the problem and have no codes since replacing this valve. I believe the valve sticks open and causes the problem. The valve was about $180 about 2 years ago and very easy to replace. Hope this helps.
jowing
Aug 5, 2012 05:03 PM
socaljoe
B7 Models
Dec 30, 2010 09:36 PM
jhsteel82
Aug 23, 2008 11:59 PM
mack29730
May 15, 2007 08:21 PM
cricket75
Jan 28, 2007 07:53 PM
