car shakes/wobbles pls help
Old Nov 23, 2007 | 08:26 PM
REALISTIC316's Avatar
Default car shakes/wobbles pls help
My 99.5 a4 1.8t qt shakes/wobbles really bad at about 20-25 mph and gets better at higher speeds but still feel the car shake. had the wheels balanced and checked for bent rims. after the balancing same problem. could it be a drive shaft out of balance? bad hub? any help would be appreciated.
Old Nov 23, 2007 | 09:20 PM
auditech79's Avatar
Default RE: car shakes/wobbles pls help
I doubt the driveline is bent, if you have 4 jack stands get the car on all four.
Dis-able the ESP slowly bring it up to speed while someone is looking at the wheels, i gaurantee you'll find whats making the wobble, or at least pin point which wheel it is.
The truth is most people that balance wheels couldn't fix a light bulb.
Old Nov 24, 2007 | 02:42 PM
rbrtech's Avatar
I have to agree. So much that I would check all the lug bolts and make sure they are tight. Also if you choose to raise it grab the tires and check for play in the suspension.
fast euro
Feb 15, 2011 06:59 AM
collegekidnlv
Nov 8, 2009 03:21 AM
james0013
Nov 11, 2008 02:25 AM
chusaiyan
Oct 3, 2008 08:12 AM
heloman28
Jan 26, 2008 04:27 PM
