Carbonio intakes
Old Feb 3, 2007 | 01:20 PM
theguy1084's Avatar
Default Carbonio intakes
does anyone know anything about these Carbonio intakes and if they are worth it? I was also wondering if anyone knew where to find info on airbox mods? I couldnt turn up anything on that.
Old Feb 3, 2007 | 01:39 PM
new2me's Avatar
Default RE: Carbonio intakes
I really dont believe you searched because there are a ton of threads on this. https://www.audiforums.com/searchpro...bmitbutton=+OK+
Carbonio is a dressed up version of the stock box so if have the $$$ then get it but there is no real power gain from it.
Old Feb 3, 2007 | 01:51 PM
theguy1084's Avatar
I did search but I didnt turn up all that. Thanks anyway...so I take it there is no real gain out of an airbox mod. Its just for sound? would that be the same with the aftermarket intakes too
Old Feb 3, 2007 | 02:07 PM
new2me's Avatar
Stock is very efficiant for what it does. Any mods to it will require a heat shield to avoid loosng power.Opening the stock 1 with the "swiss cheese mod" will give you more air but is more for sound unless you areupgradingthe turbo.
Old Feb 3, 2007 | 02:27 PM
NuYorka103185's Avatar
I dont think you looked hard enough. Here is page 1 of my search results and all I put was airbox mod.
[IMG]local://upfiles/23133/A07C8B523EDE4B81B9CA24D1DF9F0C7D.jpg[/IMG]
Old Feb 3, 2007 | 03:43 PM
theguy1084's Avatar
I was looking at some pictures of some airbox mods and I am kinda confused...if you drilled holes into your wheel well wouldnt you fling water and stuff into your intake.
btw i know why i didnt find it before....because i failed to scroll down like a dumb@#$
Old Feb 3, 2007 | 03:47 PM
new2me's Avatar
Ah yes the scroll button.
You do have a chance of that which is why some dont want to do it. On the other hand the 1's that have dont seem to be having a problem with it. They also use screen material to stop things from coming in. I supose a thin peice of foam could work just as well.
Old Feb 3, 2007 | 03:51 PM
theguy1084's Avatar
the foam idea is actually a really good idea maybe ill look into that
Old Feb 3, 2007 | 04:00 PM
new2me's Avatar
When spring hits i'll be putting on the fmic and using 1 of the hoses to pipe from the air box to the front of the car. Not sure how yet cause i dont have a warm garage to design it.
Old Feb 3, 2007 | 04:40 PM
A guy actually did a mod like that. he has the tubing material like in the back of a clothes dryer pulling in air directly from the front bumper. i forgot who did it
