CEL code 0171
Hi All,
I have a 2001 A4, 1.8T and the CEL has recently illuminated. I have checked the code and it is P0171 "SYSTEM LEAN, BANK ONE". Does anyone have a clue where I should start looking in order to fix this? I don't know if it is a common code, but any advice would be wonderful.
Thanks
Thanks
Okay, I found a split vacuum hose, the one at the front of the intake manifold, probably the same one as a previous poster mentioned. I have repaired this so I'll see tomorrow if the CEL comes on again. The vacuum hose was so brittle and rotten, that I would imagine they must all be in bad shape, but that was the only one that I could find a problem with.I will probably change them all when time permits.
Thanks again for the advice.
Neil M.
Neil M.
