CEL P0301
Old Jun 27, 2006 | 10:19 PM
tooxtreme8813's Avatar
Default CEL P0301
I just got my GIAC chip installed today and when I drove the car home the CEL light came on for cylinder 1 misfire, could this have anything to do with the chip being installed ?
Old Jun 27, 2006 | 10:26 PM
acetrebo's Avatar
Default RE: CEL P0301
Clear it and see if it comes back on the same cylinder.
I wouldn't think a new chip could cause this.
Old Jun 27, 2006 | 10:32 PM
i reset the codes and they came back on for the same cylinder misfire, which cylinder is number 1
Old Jun 27, 2006 | 10:33 PM
one more thing could it be from running the car hard on the drive home ?
Old Jun 27, 2006 | 10:34 PM
and when i turned the car off and let it sit and when i turned it back on smoke was coming out of the exhaust it was white smoke and alot of it but then it stopped and the check engine light came on for cylinder 1 misfire.
Old Jun 27, 2006 | 10:38 PM
acetrebo's Avatar
Sounds like a misfire in cyl 1.
swap coil packs and see if it follows the coilpack. Otherwise, you are probably looking at a bad ignition control module, or injector. You can also check the plug and see if it is wet with gas, eliminating the injector.
You can use a voltmeter to see if you are getting current on that coil pack wire. If not, its the ICM, or really bad wires.
Old Jun 27, 2006 | 11:04 PM
alright i took out the coil pack and it looked brown and burnt and the other three were plain black and cylinder one smelled really bad
Old Jun 27, 2006 | 11:48 PM
david9999's Avatar
That is probably the bad coil pack. You can confirm the problem clearing the code and moving the coil pack to another cyl. Start the enigne and if the code now shows misfire in another cyl, you have found the problem. Coil pack about 22 dollars.
p1zl3
Aug 23, 2016 08:33 PM
Bhubbs711
Nov 12, 2012 07:19 AM
foxracing4500
Apr 3, 2011 04:25 PM
BesI
Mar 3, 2011 07:12 PM
johnjonfenomeno
Dec 12, 2007 04:16 PM
