Center vent vac hose routing?
Old Sep 28, 2006 | 01:23 PM
The Bishop's Avatar
Default Center vent vac hose routing?
For those of you who have installed a boost gauge in your center vent, what is the best way to route the vac line to the engine compartment?
Old Sep 28, 2006 | 01:38 PM
smokeU's Avatar
Default RE: Center vent vac hose routing?
i drilled a small hole in to the lower left corner of the vent. then got knee bolster off and with wire hanger I pulled the hose through the rubber gromets into the engine bay. went around the coolant reservoir and down past the washer fluid reservoir then over to the intake mani.
Old Sep 28, 2006 | 01:49 PM
brrman's Avatar
I drilled a hole though the ecu grommet and fed it under the ECU and into the car through the firewall opening - then up under the kneebolster, into the A/C run and out through the vent.
Old Sep 28, 2006 | 03:57 PM
socal_A4's Avatar
me too^^
Old Sep 28, 2006 | 09:39 PM
The Bishop's Avatar
Thanks guys, I'll let you know how it comes out.
pikollo21
Jul 14, 2013 09:05 AM
juman19
Dec 1, 2011 10:21 AM
The Bishop
Oct 6, 2006 01:50 AM
A4 the Quattro
Mar 23, 2006 01:50 AM
Dudek12
Sep 3, 2005 05:55 PM
