Changing brake fluids?
Old Sep 20, 2004 | 01:28 PM
dudley doright's Avatar
Default Changing brake fluids?
I ordered the Bentley manual and I just haven't pick it up yet. Can someone tell me the difficulty of performing this work? What tools will I need and what fluids should I get?
Old Sep 20, 2004 | 04:24 PM
ChrisB's Avatar
Default RE: Changing brake fluids?
I just changed my brake fluid a few days ago - very easy. I did a search of this forum and other automotive forums and found lots of info on the subject. I don't have time right now to search again and repost it for you but you basically just open each caliper's brake fluid fitting one at a time starting with the most distant one from the master cylinder and pump the brake pedal. When the master cylinder reservoir gets low then add more brake fluid. Stop when the new cleaner fluid flows out of the caliper fitting.
Old Sep 20, 2004 | 04:29 PM
ChrisB's Avatar
Sorry, I should have read your post more thoroughly. The tools you'll need are a turkey baster (to initially remove as much old fluid as possible from your master cylinder reservoir) and a section of clear tubing to attach to the caliper fitting (just ask at autozone - they'll know what size.) Hope this helps.
levdeb
Aug 11, 2013 09:37 AM
cnterline
Jul 5, 2009 10:46 AM
scomell
Sep 13, 2005 03:20 AM
