Changing headlight bulb - again
Old Oct 13, 2005 | 11:12 AM
Spookytooth's Avatar
Default Changing headlight bulb - again
I have read all the previous posts on this topic and none addresses my problem.
My car is a late 2002 RHD tdi Sport Avant. I need to change the right (as you sit in the car) dipped headlight bulb. I can't flip open the hatch to get at the bulb without removing the air filter housing, so I need to remove the entire lamp unit. There are two torx bolts securing it from above - these are easy to remove, but something is still holding it back on the left of the unit (as you look at it from the front of the car). Other posts have mentioned a bolt under the horizontal adjustment screw, but I can't find that screw or the bolt. It's driving me nuts cos this should be such a simple task!
Old Oct 13, 2005 | 11:54 AM
Jestnomen's Avatar
6th Gear
Default RE: Changing headlight bulb - again
Here, read this tuturial. It had directions in it to remove the headlights.
http://www.audiworld.com/tech/ext40.shtml
Old Oct 14, 2005 | 01:16 PM
Thanks for that. Easy when you know how!
krishcanag
Mar 29, 2011 04:59 PM
gstevens26
Mar 21, 2010 12:27 PM
SourDoh
Nov 12, 2008 06:06 PM
Havors
Aug 3, 2006 10:42 AM
The Stig
Feb 16, 2006 11:07 AM
