changing out axles
Old Jan 22, 2008 | 08:42 PM
heloman28's Avatar
Default changing out axles
OK, I have the DIY for the right front axle replacement. I read somewhere on Audiworld where the guy got the axle off by jacking up the hub and letting the axle fall out instead of taking out the control arm bolts. Is it wise to do this, and are the control arm bolts really that big of a pain in the ***?
Old Jan 22, 2008 | 09:01 PM
dankhound's Avatar
Default RE: changing out axles
Jacking up the hub wont get you any play away from the transmission, which is what you need. Depending on whether the bolt is rusted in place in can be a major pain to get out or no problem.
Old Jan 22, 2008 | 10:34 PM
kendalll's Avatar
I tried to follow the DIY that you're talking about on Audiworld But after getting stuck not being able to get the bottom control arm out of the vertical I tried the bolt at the top with the two upper control arms, came out and went together again easy as could be! I'd try the pinch bolt at the top first.
Old Jan 23, 2008 | 06:08 AM
heloman28's Avatar
got it. actually, the DIY I have printed out tells me to remove the pinch bolt, if I'm not mistaken. thanks yo-
Sheasta
Oct 30, 2012 01:55 PM
AudiSicknessS4
Sep 1, 2011 05:15 PM
rockywoz
Mar 10, 2011 06:39 PM
gDmM@NnY
Aug 18, 2010 10:32 PM
ggoodling
Sep 8, 2007 12:23 PM
