Changing Rotors. DIY Help?
Old Dec 17, 2005 | 08:40 PM
rogue2's Avatar
Default RE: Changing Rotors. DIY Help?
I did it this morning. Those instructions were perfect. The rotors were not rusted on at all, they just fell right off. The thing that took the longest was getting off the first set of 17 mil bolts. I destoyed a cheap ratchet trying to get them off but my Craftsmen set held up fine.
I think i will go ahead and do the rear ones on monday. Thanks again for the help.
Old Dec 17, 2005 | 08:52 PM
sandman's Avatar
dont forget to get the special tool that rotates the piston as it compresses it for some reason thats how the rear works but not the front.
Old Dec 17, 2005 | 09:42 PM
GraffixWB's Avatar
Just use a big C clamp ., Worked perfect for me last night
Old Dec 17, 2005 | 09:43 PM
rogue2's Avatar
I won't need that tool if i am not changing the pads, will i? I just slid the old ones back on for the front breaks.
Old Dec 18, 2005 | 12:27 AM
sandman's Avatar
yea youre right.
Old Dec 18, 2005 | 12:28 AM
sandman's Avatar
ORIGINAL: GraffixWB
on the rear? hmmmm mine had to be twisted at the same time[:@]
Old Dec 18, 2005 | 12:36 AM
bhj0887's Avatar
Default .
Yea you can use a C-clamp.
Twist, back off, twist, back off. it should twist and push the piston at the same time, but you have to let off to ease the pressure off of them.
Depends how worn your rotors are. Sometimes they just won't fit back between the pads. I'd reccomend to bleed the brakes after.
Start in the rear, furthest from the MC, then work your way around.
Old Dec 18, 2005 | 04:28 AM
  #18
slimmj0k3r's Avatar
ORIGINAL: sandman
its really easy, kindof. all you do is remove the wheels and calipers and they theoretically should fall right off, but usually they are rusted on and it takes some force to remove them.
a hammer will do the trick...thats what i do, just dont hit any of the studs
and bleeding the brakes is a good idea, pretty easy as well
Old Dec 22, 2005 | 04:34 PM
  #19
rogue2's Avatar
Rear disks completed. Audiworld.com is a really great resource. Thanks for all the help guys. Breaking is a lot smoother without the frack'n DIY, cross drilled, warped rotors. I am really starting to love this little car.
saifxnyc
Oct 24, 2012 06:18 PM
dale55
Apr 25, 2010 12:19 PM
EvilA4
Dec 5, 2009 10:11 PM
b0b0
Apr 16, 2009 11:13 AM
madridlover
Sep 27, 2007 10:53 PM
