Changing Spark Plugs
Old Aug 28, 2005 | 02:31 AM
snogoer's Avatar
Default Changing Spark Plugs
I've just purchased a 98 A4 1.8 Turbo with 93,000 miles. I'm doubtful that the plugs have ever been changed. I'd like to change them on my own. Is it a big job on this vehicle? I just had the timing belt, dampner, tension roller, and roller as well as serpentine belt replaced so would like to save some $$ and do myself. I've been told in the past that if the plug wire look OK on a vehicle, its not really necessary to change them?? What is the best plug to use - Bosch or NGK??
Thanks!
Old Aug 28, 2005 | 02:36 AM
audiboy1618's Avatar
Default RE: Changing Spark Plugs
Nope, not at all. Simply pull your engine cover off. You will see 4 coilpacts on top, Loosen all all 8 hexs holding them down. Use a deep socket and extension to loosen them. Throw in ur new plugs( i use ngk brk7es) and tighten them to like 17ftpd, just basically tight, u dont u need to be exact. Make sure u get the right coilpacks back in the right cylinders too.
Old Aug 28, 2005 | 08:38 AM
david9999's Avatar
Don't forget to check the gap on the plugs and use antiseize compound on the top half of the threads.
Old Aug 28, 2005 | 02:20 PM
fillup's Avatar
whats the gap size?
Old Aug 28, 2005 | 02:29 PM
beefski's Avatar
if the plugs are mulit pronged there is no gap necessary
Old Aug 28, 2005 | 06:39 PM
STEVE36's Avatar
ORIGINAL: audiboy1618
I would be. 93k on the clock without a spark plug change? If that is true then you will really benefit from doing this..
jlight113
May 4, 2010 10:44 PM
Snapperanton
Jan 26, 2010 04:29 PM
dpatt420
Jun 26, 2008 09:32 PM
Marek
Mar 16, 2005 01:54 PM
a224932
Oct 31, 2004 11:51 PM
