Anything I need to know on changing my spark plugs?
Old Oct 29, 2004 | 09:04 PM
a224932's Avatar
Default Anything I need to know on changing my spark plugs?
I am going to attempt to replace my spark plugs. (did the oil change with synthetic and changed air filter). Is there anything special I need to know about changing the plugs? I appreciate all the help you guys have given me so far. Also how often should I replace my plugs? (I am trying to do oil change, air filter change and plugs at the same time as it is easier to keep track.
Old Oct 29, 2004 | 09:21 PM
CRAZYHAWK's Avatar
Default RE: Anything I need to know on changing my spark plugs?
If you can use NGK platinum plugs , every 40,000 mi.
Tighten to 22 foot pounds torque. If the plugs have a washer on them , hand tighten then turn the wrench 5/8 around. 5/8 = 225 degrees
I bought my platinum plugs from www.rockauto.com
for $47.77
Old Oct 30, 2004 | 03:55 AM
audiboy1618's Avatar
Yeah, make sure you know what your doing before you tear the old ones off.
Old Oct 31, 2004 | 05:06 PM
shon's Avatar
make sure the gap is right
Old Oct 31, 2004 | 11:51 PM
Doose's Avatar
And don't buy iridium plugs. At least Denso's.
jlight113
May 4, 2010 10:44 PM
Snapperanton
Jan 26, 2010 04:29 PM
dpatt420
Jun 26, 2008 09:32 PM
snogoer
Aug 28, 2005 06:39 PM
Marek
Mar 16, 2005 01:54 PM
