check engine..... !!!!!!!!!!!!!!!!!!!!
Old Sep 11, 2007 | 12:40 AM
onepoint8tee's Avatar
Default RE: check engine..... !!!!!!!!!!!!!!!!!!!!
I take it your cel is flashing and you have minimal power with stuttering performace??? If its driveable, go to auto zone or advance auto parts and get your ecu scanned. Come back and post the codes here. We will keep you from getting ripped off/spending $6k to get it fixed. Its probably just a misfire from a bad coil pack. The fault codes will tell us which cylinder(s) is missing, if that is in fact the problem.
Old Sep 11, 2007 | 12:42 AM
Sacha1.8T's Avatar
6k???????? are u serious....
i have a garanty,.. is it possible to reflash it stock and give it.... unless its cheaper than 6k...
thxxxxxx
Old Sep 11, 2007 | 12:44 AM
Sp33d07's Avatar
why dont you take the bov off and put the the dv back on and reset you ecu, drive for little and see if the problem is till there. i messed around with the bov for a while bc it sounds nice i know but its not worth it thats why i have adjustible bov/dv gfb valve but i used it for dv.
Old Sep 11, 2007 | 12:49 AM
ORIGINAL: Sacha1.8T
thxxxxxx
You said it costed you 6k to get your golf fixed every time. Im saying we can help you get it fixed for less than that.A lot less. I hope you were joking.
joeynach
Aug 27, 2011 06:57 PM
mikeysline06
Nov 4, 2010 10:32 PM
parlayin
Feb 10, 2010 12:33 PM
jeitjet
Jul 20, 2008 03:27 AM
huyaroo
Sep 12, 2007 03:37 PM
