check engine
Old Apr 9, 2005 | 02:35 AM
skidplatexa4's Avatar
Default check engine
My check engine light came on again on the ride home from the hospital (had to go get checked out motorcycle accident long story) anyways the code comes up as random engine misfire. I've replaced the coil packs, the plugs, and the output stage. Any ideas I'm getting frustrated and its getting expensive.
Old Apr 9, 2005 | 02:41 AM
ImolaS4's Avatar
Default RE: check engine
What's the exact code #??
Old Apr 9, 2005 | 02:45 AM
i cant remember the code # but it came back as random cylinder misfire when i cross referenced the # this has been happening on and off for a while. It will be fine for a while and then the check engine light comes on sometimes it will actually reset itself.
Old Apr 9, 2005 | 03:00 AM
ImolaS4's Avatar
Yeah, but I have a reference that may have more detail as to the cause, if you can get the actual number.
I can look it up tomorrow, if you can get the number.
Old Apr 9, 2005 | 03:04 AM
thanks Imola ill stop at the shop tomorrrow and scanit in the morning hopefully this will go away soon. Thanks for the help you guys are very helpful.
Old Apr 10, 2005 | 03:10 AM
So i checked the code today it came up as:
16644- misfire cylinder #1
16645- misfire cylinder # 2
I've already replaced the coil packs plugs and the output stage this month and the check engine light keeps coming on at random. I reset the light and it has'nt been back on since.
joeynach
Aug 27, 2011 06:57 PM
mikeysline06
Nov 4, 2010 10:32 PM
parlayin
Feb 10, 2010 12:33 PM
jeitjet
Jul 20, 2008 03:27 AM
huyaroo
Sep 12, 2007 03:37 PM
