Check Engine Light
Old Oct 8, 2005 | 05:41 PM
Jeff's Avatar
Zombie Defense Force
Default Check Engine Light
Ok so every one is complaining about there CEL. so i got my car scaned and here is my list
17743 - Engine Torque Monitor 2 : Controle Limit Exceeded
P1335 - 35 - 10 - - - Intermittent
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35 - 00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35 - 00 - -
16685 - Cylinder 1 Misfire Deteced
P0301 - 35 - 00 - -
16687 - Cylinder 3 Misfire Deteced
P0303 - 35 - 10 - - - Intermittent
16686 - Cylinder 2 Misfire Deteced
P0302 - 35 - 00 - - - Intermittent
17535 - Fuel Trim: Bank 1 (Mult) : System too Rich
P1127 - 35 - 10 - - - Intermittent
16705 - Engine Speed Sensor (G28) : Implausible Signal
P0321 - 35 - 10 - - - Intermittent
17511 - Oxygen (Lambda) Sesor Heating: B1 S1 : Performance too Low
P1103 - 35 - 10 - - - Intermittnet
Old Oct 8, 2005 | 05:45 PM
skidplatexa4's Avatar
Default RE: Check Engine Light
Damn that's alot of misfires across the board. Did you check the plugs and replace those sh!tty coil packs. You are not burning all of the fuel that is being delivered to the engine, and it is probably dummping into your cat giving you the Catalyst Bank 1.
Old Oct 8, 2005 | 05:47 PM
Jeff's Avatar
all the miss fire codes come at idle, when im under load i dont miss fire, and the cat is becasue both my o2 sensors are b4 the cat becasue for a while i didnt have one so its not a big deal. plugs are bradnew and working. i dont think i have any problems with the coilpacks. where could i get new ones
Old Oct 8, 2005 | 07:18 PM
flyboy's Avatar
+ are there upgrades for the coil packs?
Old Oct 9, 2005 | 04:43 AM
Jeff's Avatar
dont know if there are any, does anyone have a place i can get them
Old Oct 9, 2005 | 05:39 AM
I believe lltek offers upgraded coil packs.
Old Oct 9, 2005 | 10:16 AM
CRAZYHAWK's Avatar
For a 1.8t, there was a recall for 2001 coil packs. See a dealer.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
