Check Engine Light?
Old Dec 23, 2005 | 05:03 PM
joelml's Avatar
Default Check Engine Light?
A few days ago my check engine light came on and i wasnted to know what could cause that. also around the same time, it was in the morn, i took off the e-break and stated to go and then the car beeped at me and the break light started to flash???? what could cause that?
Old Dec 23, 2005 | 05:04 PM
joelml's Avatar
Default RE: Check Engine Light?
sorry its a 2001 a4 1.8t 5spd
Old Dec 23, 2005 | 05:06 PM
Jeff's Avatar
Zombie Defense Force
there are a million things that could do that, i would take it to auto zone and see what codes u can pull with a vag com, was ur ebrake all the way down?
Old Dec 23, 2005 | 05:10 PM
joelml's Avatar
yeah, brake was all the way down, i stopped and then re applied it and the disengaged it again. but it still did it.
Old Dec 23, 2005 | 05:14 PM
Jeff's Avatar
ur switch may be broken that senses if the brake is up or down, but i have never herd of that before
Old Dec 23, 2005 | 05:55 PM
flyboy's Avatar
check to see what the break fluid leavel is at. if its low, chanses are, the brakes need to be doon. don't fill it up. you'll be taking back out when you do the brakes.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
