Sponsored by:
Sponsored by:
Check engine light
Old 03-06-2006, 02:38 PM
ram's Avatar
ram
ram is offline
Default Check engine light
Hii all,
Since few days my check engine light is on, so I went to autozone to check whats the problem they run some test and found this code on their computer code “P0116”
‘this was the report given by them – the PCM has determined that the input from the engine coolant temperature sensor changed too little or too much for current engine operating conditions’
Is it possible for me to fix this sensor ‘if so could any one help me in this regard and where can I get this sensor’
Thanks,
Ram.
Old 03-06-2006, 02:44 PM
aRIf's Avatar
Default RE: Check engine light
I love CEL. It tells you what is wrong with your car.
it is a small part that you can get it for $15 from ecs tuning.
Old 03-06-2006, 03:12 PM
InsaneHatter's Avatar
It can be cheaper to depending on your MY (Model Year)
Its easy to replace...
Just look on the back of your engine.
Find the sensor.
Unplug the sensors wiring harness.
Remove the clip that holds the sensor on, pull towards the cabin of the car.
Pull out the sensor.
You will spill coolant , so you can put towels/something to catch that with.
Put new sensor in.
Repalce Clip.
Replace wiring harness.
Bada bing bada boom!
Old 03-06-2006, 03:16 PM
ram's Avatar
ram
ram is offline
so on ecstuning will they sell based on this code 'P0116' or is there any specific method to find this sensor.
waiting for your reply.
Thanks,
Ram.
Old 03-06-2006, 03:52 PM
get a light... its on the back of the engine.. se what color it is
Old 03-06-2006, 03:58 PM
Jestnomen's Avatar
6th Gear
Old 03-06-2006, 05:38 PM
ram's Avatar
ram
ram is offline
Hii InsaneHatter,
I checked it this afternoon, behind the engine there are many sensors and near to coolant there is one which is blue in colour, so do u think is this the one,
there are some other sensorw which are on the other side of enginer there are around 4 to 5 sensors but the first one i think is connected to coolant.
so shall i go ahead and buy it from ecstuning and also do u think it will be difficult in taking out the sensor because it is below coolant.
Thanks,
ram.
Old 03-06-2006, 06:07 PM
coolant temp sensor is green plastic 4 pin ( green because its emissions related ) black is dash read out blue is fan switch
Old 03-06-2006, 06:48 PM
ram's Avatar
ram
ram is offline
how do i know that the green one is correct one because it is far away from engine coolant.
can you guide me shall i send the pic of where it is located.
Thanks,
ram.
Old 03-06-2006, 06:57 PM
from your last posts its a 2.8 but more info is required like age of car/engine size/ are the back seats comfortable so I can use it for my bird lol
Quick Reply: Check engine light
