Check engine light????
Old Oct 15, 2006 | 11:41 PM
CluTcH/B5's Avatar
Default Check engine light????
I did the airbox mod on my 96 2.8 5speed.. Sweet
My problem happend down the road a little. I was on my home and the check engine light came on.. So I popped the hood when I got home, and I noticed the the hose connecting to the airbox had come off at the clamp. I put it back on, and I pretty sure it's the reason the light came.
Question???? How the hell do I get the damn light off.. Can I unplug the batt. Or do I have to take it somewhere.??
Old Oct 15, 2006 | 11:42 PM
CluTcH/B5's Avatar
Default RE: Check engine light????
Oh and yes I tried the search
Old Oct 15, 2006 | 11:44 PM
BadLuckAudi's Avatar
probably have to have it cleared but you can try disconnecting the batt, just be sure you have your radio code
Old Oct 15, 2006 | 11:47 PM
wood_e's Avatar
ugh, if you SEARCHED you'd find that you need to pull the code and solve the problem. It might be completley unrelated to your airbox mod...
Most auto parts stores scan codes for free. Take it there and post back here.
Old Oct 15, 2006 | 11:49 PM
CluTcH/B5's Avatar
I don't think it has to do with the mod.
But the diconnection of the hose..
Oh I have an after market stereo
Old Oct 15, 2006 | 11:51 PM
ok so try dissconnecting hte batt its not gunna hurt anything and it may clear, also it may clear on its own
ORIGINAL: CluTcH/B5
Old Oct 16, 2006 | 12:17 AM
CluTcH/B5's Avatar
I'll just try it and see ifit works.. I'll post results.
Old Oct 16, 2006 | 12:24 AM
cool cool hope it works for ya
ORIGINAL: CluTcH/B5
Old Oct 16, 2006 | 12:28 AM
acetrebo's Avatar
Pull the neg battery cable for 5 minutes, that will clear it for sure, just make sure you have the radio code.
It will take a few (40) miles for the ecu to get back to normall totally.
wood_e's Avatar
Yeah, I say get the code first. If it points to the secondary injection pump then reset the ECU.
