check engine light
Old Apr 2, 2007 | 05:24 PM
alxjhn's Avatar
Default check engine light
i have a 1998 a4 2.8 v6. my check engine light is on. i get the p0302 code and p1300 code. i replaced the icm and spark plugs and spark plug wires. i still get the same code for it. WHAT IS WRONG?????? BEEN TRYING TO FIGURE THIS OUT FOR A WHILE.
Old Apr 2, 2007 | 05:46 PM
SacTown_Vlad's Avatar
Default RE: check engine light
P1300 - Misfire detected Reason: Fuel level too low… just guessing, bad fuel pump, I would do some search maybe even call dealer and ask how many gallons/min. your pump should push.
Old Apr 2, 2007 | 06:31 PM
fuel filter...
P1300: things to check according to Bentley CD
Fuel level less than 2 gallons, add fuel to tank
Check signal from sender for fuel gauge -G-:
Electrical Wiring Diagrams, Troubleshooting &Component
Locations
Check wire connection between Engine Control Module (ECM)
and instrument cluster according to wiring diagram:
Electrical Wiring Diagrams, Troubleshooting & Component
Locations
I guess the thinking is that if the Fuel Sender in the tank reads "higher" than actual, you could run into a situation where the pump sucks vaour and that causes the engine to miss?
Note, I usually mention fuel filter because they are always overlooked. Sure AUDI says that they are good for the life of the car, but I've seen them plugged as early as 30K km.
Usually a "Fuel Trim Code" is set if the ECU has to compensate too much... but I've read about high fuel trims not setting codes as well.
When you take the filter out, shake it up and pour the contents into a glass jar, shake and drain every few seconds... once empty, blow through the filter in the direction of the arrow (on the filter). A clean filter will have no resistance to blowing.
Old Apr 3, 2007 | 12:13 AM
david9999's Avatar
P0302 is cyl 2 misfire. Have you cleared the codes and they come back?
Or did you replace the parts and not clear the codes.
for some reason, I can't find P1300 in my bentley CD.
Old Apr 3, 2007 | 01:59 AM
alxjhn's Avatar
i cleared the codes each time i changed a thing. it still happens. i am going to check the fuel injector tommorow
Old Apr 5, 2007 | 01:01 PM
alxjhn's Avatar
i checked everything. i swaped the injector into another cylinder i am still getting a misfire in cylinder 2.
any ideas?????????
Old Apr 5, 2007 | 01:19 PM
acetrebo's Avatar
Replace the ICM. Its bad.
here's a test....
http://forums.audiworld.com/a4/msgs/1594531.phtml
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
