Check Engine Light On
Old May 30, 2007 | 08:14 AM
ACat299612's Avatar
Default Check Engine Light On
My check engine light started flashing the other night on the way home from work. When I start it, it now stays solid. Two questions. First, is it OK to drive it over to a mechanic to have it tested with it solid? Two, the coolant level is a little low, just below the Min mark. I assume this is not the cause of the problem?
Thanks in advance for your help.
Old May 30, 2007 | 08:16 AM
akielb's Avatar
Default RE: Check Engine Light On
blinking = BAD - solid = not so bad, Blinking usually means missfire. take it to autozone and have them check your codes for you. bring the codes back here and post them and we'll tell you what the problem is.
Old May 30, 2007 | 08:52 AM
techbod's Avatar
low coolant level with turn the CEL on because its a threat to the engine at least that's how the ECU sees it
Old May 30, 2007 | 10:41 AM
ACat299612's Avatar
I took the car to a friend that can diagnose, and it came up with a cylinder #2 misfire. I am hoping it is a sparkplug or something easier along those lines. Does this seem reasonable?
Old May 30, 2007 | 10:45 AM
techbod's Avatar
change the coil pack with an other one and see if the code goes away ( also change the spark plug ) the code is P0302 cylinder 2 misfire
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
