check engine light on after borla exhaust install
Old May 23, 2007 | 11:03 PM
A4Rollin's Avatar
Default check engine light on after borla exhaust install
i installed a full 2.5 borla exhaust system with 2.5 hi-flow cat and downpipe. After 4 days of the install, my check engine light went on. I thought it might have something to do with emissions.... So then the light went off and didnt think about it anymore. Then 2 days ago the damn thing came on again!!! There are no problems driving the car mechanically so im guessing the emissions sensor still?..... Any suggestions from you guys, and anyway to cancel it out so it stops turning on?
Old May 23, 2007 | 11:07 PM
96audia4's Avatar
Default RE: check engine light on after borla exhaust install
Scan for codes. Could easily be an exhaust leak or the high flow cat might not be cleaning up the emissions enough. Did you install the gasket between the turbo and cat?
Old May 23, 2007 | 11:13 PM
A4Rollin's Avatar
yah i installed all gaskets and the exhaust system is all welded together except downpipe and hiflow cat obviously. Checked for leaks after the install and everything was fine
Old May 23, 2007 | 11:29 PM
96audia4's Avatar
Yeah...thats the problem with high flow cats - they don't always satisfy emissions requirements. I would say, try using a spark plug non-fouler in the secondary (post-cat) o2 sensor. I used two for my testpipe, but one might do it for you.
Old May 23, 2007 | 11:37 PM
A4Rollin's Avatar
what did you do with the sensor? If it wasnt pluged in-use wouldnt you have the same problem with the check engine light coming on?
Old May 23, 2007 | 11:41 PM
A4Rollin's Avatar
anyone else with this problem? I know a couple of you have the full borla exhaust from a while back...........................
Old May 23, 2007 | 11:46 PM
96audia4's Avatar
Sorry...the pic doesn't show the sensor. You just plug it in on the other side of the non-fouler. This is meant to take the sensor out of the main stream of exhaust flow, thus not picking up harmful measurements. You will also need to drill out the non-fouler a little bit for the sensor to fit.
Old May 24, 2007 | 10:09 AM
beast a4's Avatar
streamline industries in salt lake they really need to get a website. but yea, theyhave these sensor spacers or somethin they put on mine and it hasnt turned back on since.
425macchi
Jan 30, 2009 05:03 PM
RyanSweeney
Jan 20, 2009 02:15 AM
Stretch1.8
Dec 19, 2007 11:40 PM
Bogie
Oct 17, 2007 11:41 AM
Bogie
Oct 13, 2007 05:28 PM
