Check engine light is ON ....again!
OK guys, I am starting to give up on this car. I have another CEL and it points to vacuum leak on one of the hose. I have changed all the hoses and I am still having the CEL. I have a Y-shaped rubber connector changed today and still have the CEL. Can someone tell me what you have encountered with a vacuum leak. I have a 2001 A4 1.8TQ AWM engine.
you realize the CEL won't clear itself until it goes thru at least an entire drive cycle (~200 miles i think). you need a VAG-COM or at least an OBDII reader to clear the code, then retest after each component you replace.
ORIGINAL: insuite
iv experience the CEL to come on after everyt ime im over 100 mph
this blows if its meant to be that way
this blows if it needs to be fixed because its not supposed to happen that way
