Check engine light is ON ....again!
Old Jul 15, 2005 | 01:47 AM
dudley doright's Avatar
Default Check engine light is ON ....again!
OK guys, I am starting to give up on this car. I have another CEL and it points to vacuum leak on one of the hose. I have changed all the hoses and I am still having the CEL. I have a Y-shaped rubber connector changed today and still have the CEL. Can someone tell me what you have encountered with a vacuum leak. I have a 2001 A4 1.8TQ AWM engine.
Old Jul 15, 2005 | 12:39 PM
insuite's Avatar
Default RE: Check engine light is ON ....again!
you realize the CEL won't clear itself until it goes thru at least an entire drive cycle (~200 miles i think). you need a VAG-COM or at least an OBDII reader to clear the code, then retest after each component you replace.
Old Jul 15, 2005 | 01:45 PM
ORIGINAL: insuite
I do have a VAGCOM and cleared the fault but it does come back after 100Km. So, I know it is a minute leak and it take that much time to register.
Old Jul 15, 2005 | 05:06 PM
luvin_the_rings's Avatar
iv experience the CEL to come on after everyt ime im over 100 mph
this blows if its meant to be that way
this blows if it needs to be fixed because its not supposed to happen that way
Old Jul 15, 2005 | 06:59 PM
david9999's Avatar
What code are you getting?
Old Jul 16, 2005 | 06:28 AM
dont got a vagina-com
but it goes away after 200 miles, so im not worried
Old Jul 17, 2005 | 01:38 AM
ORIGINAL: david9999
System too lean.
Old Jul 17, 2005 | 09:45 AM
david9999's Avatar
Post the actual code.
Could be vacuum leak, MAF, O2 sensor.
Old Jul 17, 2005 | 04:00 PM
ORIGINAL: david9999
I know it is a vacuum hose problem. Do you have CEL issue as well?
Old Jul 17, 2005 | 07:40 PM
david9999's Avatar
Yah, probably the MAF.
