Check engine light is ON ....again!
Old Jul 18, 2005 | 02:10 AM
dudley doright's Avatar
Default RE: Check engine light is ON ....again!
ORIGINAL: david9999
Yah, probably the MAF.
What are your symptoms if you have a MAF problem or O2 problem? How can anyone determined if any of these expensive parts need to be replaced?
Old Jul 18, 2005 | 07:21 AM
david9999's Avatar
No power, lean condition, no vacuum leak seen, vagcom logging.
Old Jul 18, 2005 | 12:50 PM
yellowa4's Avatar
Member
going thru the same stuff myself... CEL's been on and off for about a month now. Codes pointed to the o2 so took it to my mech and replaced the o2 sensor (front).
he said that the rear was fine but lo and behold the CEL lit up again. codes now point to a lean mixture. Gonna have to get the rear one replaced.
Any suggestions as I just want to NOT see the CEL again. Also, is there a point where I sould bite the bullet and take her to the dealership... but then again, I may have to pay for this peace of mind...
-- 2000 A4 1.8 T Q --
B
Old Jul 18, 2005 | 12:54 PM
ORIGINAL: yellowa4
B
You should buy a VAGCOM to see what the codes. I have a feeling you may just need to replaced the vacuum hoses. Those cloth covered rubber tend to rot and break. I just replaced 3 of them over the weekend and when I pulled them off the whole rubber just crumbled in my fingers. Anyone know where I could get metal braided hoses?
Old Jul 18, 2005 | 01:27 PM
TGPorsche96's Avatar
if you have a K&N air filter on the car then the o2 sensor might be clogged. ...then again it could be the leak that you said...dont know whats wrong man
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
