Check Engine Light Code
Ok, went to Autozone, got code P1137. They told me it means o2 sensor is bad and that it was lean (according to code). Problem is there are 2 o2 sensors (before and after catalytic converter), how the hell do i know which one. Trying to avoid dealership still... Any suggestions?!
THANKS FOR ALL HELP IN ADVANCE!
You guys really need to post specifics about your car, model, year, etc...
Long Term Fuel Trim Add.Fuel,Bank1
Could be a faulty MAF sensor, vacuum lines or O2 sensor. Have you considered buying a Vag-Com for more specific diagnostics?
Clear the code and see if it comes back before you go replacing anything. Sometimes they are just a fluke. You can clear the code by disconnecting the battery for an hour or so.
By the way, car is 2000 1.8tQ with 113K miles.
Here's something else Jest. I bought car in June, and it had a check engine light code- same one for the 02 sensor, a guy with a M3 checked it for me. It was there for about a month and a half, and I was too broke to do anything about it. Then in middle of June, it disappeared and did not come back until 2-3 weeks ago. I don't know if that means anything.
You think I should still just unhook the battery. Its just that main hose right? (I'm an idiot when it comes to do it yourself things).
Thanks
Thanks
Battery is located between engine compartment and cabin. Remove the plastic cover and disconnect the ground (-) cable. Reconnect about an hour later. This should reset the error code.
You can do that to get rid of the idiot light. But you still have an underlying issue here. Since you are not mechanically inclined you are goign to want to get it fixed. It's nothing urgent, so whenever you get around to it. Just don't let it go on for a long time.
I'm not so sure it is a O2 sensor. How many miles do you have on your car? Usually when a O2 sensor goes bad they spit one of these codes:
16514 P0130 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 1) A
16515 P0131 O2 Sensor Circuit - Voltage Low (Bank 1 Sensor 1) B
16516 P0132 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 1) A
16517 P0133 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 1) B
16518 P0134 O2 Sensor Circuit - No Activity Detected (Bank 1 Sensor 1) A
16519 P0135 O2 Sensor Heater Circuit - Malfunction (Bank 1 Sensor 1) A
16520 P0136 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 2) A
16521 P0137 O2 Sensor Circuit - Low Voltage (Bank 1 Sensor 2) B
16522 P0138 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 2) A
16524 P0140 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 2) B
16525 P0141 O2 Sensor Heater Circuit - Malfunction (Bank 1 Sensor 2) A
16534 P0150 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 1) A
16536 P0152 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 1) A
16537 P0153 O2 Sensor Circuit - Slow Response (Bank 2 Sensor 1)
16538 P0154 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 1) A
16539 P0155 O2 Sensor Heater Circuit - Malfunction (Bank 2 Sensor 1) A
16540 P0156 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 2) A
16542 P0158 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 2) A
16543 P0159 O2 Sensor Circuit - Slow Response (Bank 2 Sensor 2)
16544 P0160 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 2) A
16545 P0161 O2 Sensor Heater Circuit - Malfunction (Bank 2 Sensor 2) A
17509 P1101 O2 Sensor Circuit (B1-S1) Voltage Too Low/Air Leak D
17510 P1102 O2 Sensor Circuit Heating Circuit (B1-S1) - Short to B+ A
17511 P1103 O2 Sensor Circuit Heating Circuit (B1-S1) - Output Too Low A
17512 P1104 O2 Sensor Circuit (B1-S2) Voltage Too Low - Air Leak A
17513 P1105 O2 Sensor Circuit Heating Circuit (B1-S2) -Short to B+ A
17514 P1106 O2 Sensor Circuit (B2-S1) Voltage Too Low - Air Leak A
17515 P1107 O2 Sensor Circuit Heating Circuit (B2-S1) - Short to B+ A
17516 P1108 O2 Sensor Circuit Heating Circuit (B2-S1) - Output too Low A
17517 P1109 O2 Sensor Circuit (B2-S2) Voltage Too Low - Air Leak A
17518 P1110 O2 Sensor Circuit Heating Circuit (B2-S2) - Short to B+ A
Thank God this whole thing will be solved next week. A guy who is doing all my aftermarket mods from EHT motorsports agreed to figure this whole thing out for free and just charge for the part.
Phew, I'm glad this whole thing is solved.
