check engine light help
Old Sep 21, 2006 | 01:29 AM
dan321's Avatar
Default check engine light help
codes
p0102 maf circuit failure
p1137 long term fuel trim additive system too rich (bank 1)
can clear and they come back instantly
Old Sep 21, 2006 | 09:36 AM
david9999's Avatar
Default RE: check engine light help
Probably a bad mass air flow sensor.
Old Sep 23, 2006 | 03:39 AM
dan321's Avatar
the maf only has 30k on it is there anything else I should do before replacing it.
Old Sep 23, 2006 | 03:54 AM
bugedbass's Avatar
if you have P0102 check the wiring on the mass air flow sensor. Have you replace your air filter lately? if you have problably you pull the conector from the wires.
Old Sep 23, 2006 | 04:59 AM
wood_e's Avatar
Try cleaning your MAF
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
