check engine light. need help !!!!
Old Jul 5, 2006 | 01:45 PM
jarocho77's Avatar
Default check engine light. need help !!!!
So I installed a K&N filter about 5,000 miles ago I my check engine light came on 3 days ago while I was driving. I took the car for service @ 40,000 miles and the dealership guy said that because the K&N uses oil that my air sensor would get 'dirty' I maybe my check engine light would come on it would be expensive to either clean it or replace my sensor. Any of you guys had this problem ???? How can I get ride off this now without taking the car in the dealership ????
Do you think this could be my problem ????
I pressed the little wrench button on my dash and it says next service in 5,000 miles.
Old Jul 5, 2006 | 08:30 PM
dafrazi's Avatar
Default RE: check engine light. need help !!!!
Find someone with VAG-COM and have them scan the car or take your car to Autozone or Advance Auto Parts and have them scan your car for codes. Report back with the what codes you get.
Old Jul 5, 2006 | 08:33 PM
jarocho77's Avatar
How much would this cost ????
Is this the only way ???
Old Jul 5, 2006 | 08:38 PM
dafrazi's Avatar
Autozone and Advance Auto Parts will scan your car for free. It's the only way to see why the CEL is on without taking it to the dealer.
Old Jul 5, 2006 | 10:58 PM
wood_e's Avatar
It is possible your MAF got dirty, but it could be a number of causes. Get it scanned. If it IS the MAF then clean it with electronics cleaner.
Old Jul 6, 2006 | 01:19 PM
jarocho77's Avatar
Thanks guys i appreciate the feedback. I'm taking it after work today !!!!
Old Jul 8, 2006 | 07:10 PM
jarocho77's Avatar
So here's the result: DTC codes---- P0171 System Too lean ( bank 1 ) The guy at advance auto parts recomended I run a Injector cleaner and run ti for a while and that after like 3 or 4 starts it should reset itself if not take it back in to plug it in again.
I always buy SHELL ( 91 octane ) gas but last time I got it from conoco maybe my car is used to shell gas and putting the other one had sometthing to do with this. Does anybody know what the dealership do at 50,000 mile service ??? maybe is acting up before the service.
Thanks everyone for the feedback !!!!
Old Jul 8, 2006 | 08:06 PM
CRAZYHAWK's Avatar
They change the engine oil and filter. They reset the service reminder. They inspect cooling, exhaust, battery, tires and brakes.
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
