chip question
Old Dec 17, 2005 | 08:03 PM
ShaodwMav's Avatar
Default chip question
i just bought my car in oct. now im wonderin if it has a "chip"...how do i find out if it does have a chip....i know throught the cruize control buttons but if its an apr and its locked out on the stock program how would i know???
Old Dec 17, 2005 | 09:55 PM
headshok2002's Avatar
Default RE: chip question
Is it fast?
Old Dec 17, 2005 | 11:59 PM
tip5's Avatar
lol
Old Dec 18, 2005 | 01:45 AM
Fieldy's Avatar
ShaodwMav,
if you are relaly in a bind, find a friend or dealer with the same year 1.8 as you and drive that. the difference of the chip is night and day...
i'm sure there is a better way to tell though.
Old Dec 18, 2005 | 02:24 AM
Slowb5's Avatar
hook up a boost gauge, if at fullthrottle it goes anywhere above 7 psi, you are chipped...also should be around 17 lbs of vacuum at idle....maybe more-maybe less. chip varying.
Old Dec 18, 2005 | 02:25 AM
onepoint8tee's Avatar
ORIGINAL: Slowb5
If its fast you are, if its not your not...
Old Dec 18, 2005 | 05:33 AM
Beer Mod's Avatar
Good ****!!! Y dont you check the revs dont the apr chips up the RPM and top speed
Old Dec 18, 2005 | 03:51 PM
ShaodwMav's Avatar
well when i acc. hard it hits like 11psi...when i let off the "go" pedal it drops to 7 than down to zero.......no neg psi reading.....
Old Dec 18, 2005 | 07:18 PM
mmart6545's Avatar
ORIGINAL: Slowb5
Wrong. He is an 01.
mmart6545's Avatar
ORIGINAL: ShaodwMav
No neg PSI reading? Do you have a supercharger boost gauge without vac readings?
Either way, 11psi on an 01...you're stock.
