Clear Corner...impossible
Old Mar 7, 2007 | 02:43 PM
banderson121's Avatar
Default Clear Corner...impossible
I am trying to do the clear corner mod on my b6 without the autoleveling feature. After I get the meatal clip and the three screws off, I cannot get the actual light out of the headlight. I unscrewed the leveling screw all the way and it still seems to be catching on it. I sat there for hours and I just can't get the light out. Does anybody know of anyother ways to get the reflector out or am I doing it wrong? Thanks
Old Mar 7, 2007 | 02:48 PM
akielb's Avatar
Default RE: Clear Corner...impossible
are you using these directions?
http://www.a4mods.com/index.php?page...earcorner.html
Old Mar 7, 2007 | 02:49 PM
No, those are for the autoleveling headlights
Old Mar 7, 2007 | 02:53 PM
M¥§T's Avatar
That mod works for both, I don't have the autolevel mod and it worked perfectly for me
Old Mar 7, 2007 | 02:55 PM
oh ok. when you did yours though, did you have trouble getting the low beam light out of the headlight. It does not show how to do it on that site and I cant get it out
Old Mar 7, 2007 | 03:03 PM
M¥§T's Avatar
Do you mean the actual bulb?
Old Mar 7, 2007 | 03:08 PM
no the whole middle lense thing. isnt that how you get the reflector out?
Old Mar 7, 2007 | 03:12 PM
M¥§T's Avatar
No, you don't take the center pieces out. After you have gotten the reflector loose, you angle the lights up and slide it out underneath them.
Old Mar 7, 2007 | 03:16 PM
oh ok. I read somewhere that I had to take the whole middle thing out and loosen the adjustment screw all the way to get the reflector out. it took me all day and I got nowhere. The only problem for me now is that my adjustment screw is all stripped. So all I need to do is take the reflector out with the dremel and then slide it under the lights. Thanks. that should definitely help
Old Mar 7, 2007 | 03:17 PM
M¥§T's Avatar
Right, just make sure you take out the small holder that is put in place of the motors(for the autolevel option) so that you can easily tilt the lights.
