CLEARING CEL...
Old Nov 3, 2005 | 01:54 PM
ALL*AUDI's Avatar
Default RE: CLEARING CEL...
So after all this I'm thinking about buying a Vag-Com, any links to anything I can do with it as to additional features. Increase rev limiter or on dash display?? Thanks
Old Nov 3, 2005 | 01:56 PM
Jestnomen's Avatar
6th Gear
No just disconnect it for a half hour or so. You'll want to do a throttle body alignment before starting too. Just turn the key to the point before starting the engine. Let it sit for 5 minutes or so. You should hear some clicking from the engine bay while it's doing it's thang.
Old Nov 3, 2005 | 02:05 PM
ALL*AUDI's Avatar
Thanks...
Old Nov 3, 2005 | 02:43 PM
acvega's Avatar
if you pull the radio fuse before you pull the battery cable, it shouldn't ask for the radio code when it is hooked up again. at least it has worked for me every single time.
Old Nov 3, 2005 | 02:59 PM
clconversion's Avatar
you can also take out your ECM and leave that sit for half an hour that will clear your code
Old Nov 3, 2005 | 03:17 PM
ALL*AUDI's Avatar
Great info guys thanks....
Old Nov 3, 2005 | 04:11 PM
CRAZYHAWK's Avatar
You'll aslo have to reprogram the one touch window feature.
Old Nov 4, 2005 | 11:05 AM
  #18
ALL*AUDI's Avatar
CRAZYHAWK Date 11/3/2005 1:11:47 PM
HOW DO I DO THAT???
Old Nov 4, 2005 | 11:36 AM
  #19
CRAZYHAWK's Avatar
Lower each window part way. Close each window, release button and press to raise again.
Old Nov 4, 2005 | 12:58 PM
  #20
TomRitt's Avatar
shouldnt it clear itself eventually after the problem is fixed? And no dont always trust the dealer
