Clicking/ Knocking
Old Jul 20, 2007 | 02:08 PM
EVOLA4's Avatar
Default RE: Clicking/ Knocking
does anybody have any idea how to prevent this w/o having to put everything back to stock?
Old Jul 20, 2007 | 02:10 PM
techbod's Avatar
ORIGINAL: EVOLA4
temps here have been around 115 lately. do you think it will harm anything.
doubtful the system is adaptive to high temps
onepoint8tee's Avatar
ORIGINAL: EVOLA4
Contact GIAC or your tunerabout it. www.giacusa.com and see what they have to say. You could get a mbc and turn the boost down a little, but that may cause other issues if your actual boost is much lower than requested by the ecu.
The hotter the intake temps are, the more likely detonation will occur if your ecu cant compensate with enough timing/fuel.
Old Jul 20, 2007 | 02:12 PM
EVOLA4's Avatar
Sounds good guys, I think i will try to get a hold of GIAC. you guys are awsome when i need help. ttyl
Old Jul 20, 2007 | 02:13 PM
You could try using a heat range cooler spark plug also. If youre not already using them, put in some NGK BKR7E gapped to .028. You should be using those anyways if youre boosting anywhere near 20 psi.
Old Jul 20, 2007 | 02:14 PM
EVOLA4's Avatar
I do need to put new plugs in. i will do that this weekend and let you know how it goes.
michaelmcgo
Aug 22, 2013 12:22 PM
bhollehday
Nov 15, 2011 11:23 AM
eurostyleb
Jun 19, 2008 01:10 PM
a3square
Oct 16, 2007 08:56 AM
