Clicking noise from during low speeds?
Old Apr 29, 2005 | 02:11 AM
cukilo's Avatar
Default RE: Clicking noise from during low speeds?
I was almost sure that it was the CV joint since i had this problem with my civic about a year ago. I'll get it looked at next month and get back to you guys with an update.
Old Apr 29, 2005 | 09:43 AM
david9999's Avatar
I'll add to the clamor. That is classical for failing CV joint, most likely outer.
Old Apr 29, 2005 | 11:19 AM
darksi3842's Avatar
if it gets to the point that stuff like your transmission is shakking a little it is definatly you alignment
Old Apr 29, 2005 | 02:09 PM
cukilo's Avatar
How long can i drive like this? Because i am going to the US this weekend and i hope that it lasts for the trip there and back thats about 1600km?
Old Apr 29, 2005 | 02:14 PM
Krule's Avatar
ako ces do amerike naleti do Atlante brate ako stignes heheeh, al nevjerujem da bi trebo daleko vozit sa tako sjebanim cv joint ako mozes pogledaj sa autoshop nekim da vide jel sigurno ili ne nemoj bezveze rizikovat
Old Apr 29, 2005 | 02:59 PM
BFlan2001's Avatar
you should be fine.....failing cv joints will function fine for months...the damage is already done, you aren't hurting anything driving on it, just take it easy at low speed turns, if it gets really bad the joint will pop off and you'll be screwed, you'll have to get it towed....
nadzi
B8 Models
Dec 4, 2011 03:07 PM
tran84m
Oct 9, 2008 11:46 PM
3.0AmuletA4
Jul 1, 2008 01:18 PM
spex
Feb 6, 2008 04:18 PM
SciGuy
Oct 3, 2005 04:38 PM
