Climate Control problem
Old Apr 5, 2005 | 11:13 AM
Suachris's Avatar
Default Climate Control problem
I have a '96 A4 1.8 with climate control. When the temp in the car is set to cool, the air coming from the centre vents are cold but from the side vents is lukewarm. Has anybody else had this problem or any idea what it might be? The dealer had the car for days and the only thing he could come up with was that the ignition switch was faulty and did not open the temp control flap. It was replaced and made no difference!
Old Apr 5, 2005 | 11:21 AM
Jestnomen's Avatar
6th Gear
Default RE: Climate Control problem
Hey Suachris, welcome to the forum.
The temp regulator flap is usually the problem for cold air.
See if you can't pull a diagnostic trouble code from the climate control:
http://www.audiworld.com/tech/int5.shtml#DiagCodes
Old Apr 5, 2005 | 11:30 AM
Suachris's Avatar
Checked, no fault codes. Any idea where this flap is and how to get to it? The Haynes manual does not show how to get to it.
Old Apr 5, 2005 | 11:33 AM
Jestnomen's Avatar
6th Gear
I think you have to pull the dash out to get to it, so it's no easy chore. I don't have my parts catalogue handy so I can't get you a diagram at this moment. I can get it to you when I get off work tonight.
Old Dec 22, 2005 | 08:45 PM
gregp1962's Avatar
Did you ever get that diagram? I'm having a problem with the heater blowing cold air. I know the heater core is hot and water is circulating. I'd like to see how to get to the temp regulator flap of the motor that controls it.
bjlong
Nov 17, 2010 10:42 PM
EZAVANT
Apr 17, 2009 05:56 PM
gschleg84
Aug 20, 2008 11:02 AM
96A4
Feb 16, 2007 12:39 PM
mikeysentra
Sep 30, 2006 04:05 AM
