Clutch and flywheel install
Old Oct 3, 2007 | 09:21 PM
kemp_travis's Avatar
Default RE: Clutch and flywheel install
the engine will NOT fall once i un bolt the sub frame?....and you have to drop the subframe to drop the trans?...
Old Oct 3, 2007 | 09:25 PM
auditech79's Avatar
You're just un-bolting the rear of the subframe, the engine wouldn't fall even if you did un-bolt the subframe, it would hang on the suspension. Now that wouldn't be good for it or the wiring harness, but un-bolting just the two large bolts on the rear of the subframe won't hurt it. You might need a couple of jacks to get it back up when your done though.
Old Oct 3, 2007 | 09:27 PM
ok, is there anything that i need to look for or watch out for when doing it...like any stuff that you have came accross to be a problem?
Old Oct 3, 2007 | 09:29 PM
auditech79's Avatar
Remember to take out the speed sensor on the driver's side of the transmission. Other than that if you buy a clutch alignment tool its pretty straight forward on a 1.8T.
Old Oct 3, 2007 | 09:34 PM
ok...b/c i dont feel like spending $75 per hr. for labor
Old Oct 3, 2007 | 09:36 PM
Bondga's Avatar
ORIGINAL: kemp_travis
ok, but i will be going with a lightened flywheels with new disc, pressure plate, and everything.
but do you have to take the driveshaft out? or how exactly do you go about doing it?. you drop the whole trans..correct?
any diff. in HP or quickness with the flywheel?
NO! you don't gain power from a clutch
the flywheel will effect your revving. and(as i've heard) you'll get a considererable amount of chater.
the clutch will just help you sustain a power transfer not give you any
chaos92287's Avatar
ORIGINAL: auditech79
The clutch is cake on a 1.8T, you just need the clutch alignment tool and your all set.
P.S. stop making cincyTT blow O-rings and search before posting.
then why is the shop charging me 700[&o] i wish i had tools and a garage
Old Oct 3, 2007 | 09:37 PM
  #18
auditech79's Avatar
I wish you lived here, we charge $125 and hour in Sac, X 10 hours to do the clutch.........yeah.
  #19
chaos92287's Avatar
ORIGINAL: Bondga
the lwfw will add hp because its able to spin faster, but if you have the a/c on a lwfw will clatter at idle
Old Oct 3, 2007 | 09:40 PM
  #20
chaos92287's Avatar
thats what they charge in S FL. the cheapest i found around town that is still decent is 68/hour x 10 hours
