clutch problems on my 97 a4 1.8t
Old May 29, 2007 | 02:24 PM
audia41997's Avatar
Default clutch problems on my 97 a4 1.8t
my clutch goes completely to the floor and doesnt go into any gears.. i heard it might be just my clutch fluid? but i cant find where that would go.. i looked under the hood and all the fluids were full.. maybe im missing it?.. i dont think my clutch is shot because there was no slipping involed.. the pedal feels waaayy to loose now like something snaped so maybe im thinking the fluid is low.. anyone with the same problem or knows what im talking about please help me.. im not trying to spend maddd money on a new clutch juist yet.. peal
Old May 29, 2007 | 02:27 PM
techbod's Avatar
Default RE: clutch problems on my 97 a4 1.8t
sounds like the clutch slave cylinder or pipes have failed
Old May 29, 2007 | 02:29 PM
audia41997's Avatar
should i try putting brake and clutch fluid in as i pump the clutch.. would that fix the problem?
Old May 29, 2007 | 02:30 PM
techbod's Avatar
its the same filler container for both but yes try it but dont overfill
Old May 29, 2007 | 02:33 PM
acetrebo's Avatar
No puddle of fluid on the ground, or evidence of fluid in the engine bay?
audia41997's Avatar
do you know know where the brake fluid container is located?? its a 97 a4. i see a white container with a sensor hooked up to it but i cant seem to find where to add the fluid
Old May 29, 2007 | 02:40 PM
techbod's Avatar
does it have this logo on it (O) that's the break fluid and the sensor on the top is also the fill point you will note the sensor dosnt turn with the cap
Old May 29, 2007 | 06:51 PM
TDRILL's Avatar
Brake fluid resevoir is up by the windsheild.
Its possible its fluid, but it sounds like a bigger problem. Not necessarily the clutch though if your pedal is really loose. Possibly sheared a pin on the clutch pedal? Otherwise I am guessing you have no hydraulic pressure in your system, but then you should see brake fluid under the car somewhere after you pump the clutch. Start snooping around and let us know what you find.
[IMG]local://upfiles/21736/702830352AA04EEC90C5FF57E3A6DF0B.jpg[/IMG]
Old Sep 9, 2007 | 07:01 PM
alexn103's Avatar
hey guys, i'm having the same problem except my brake fluid is still full and there is no leak what so ever. the clutch was stuck to the floor one day when i was driving on the freeway and so i had to pull it out with my foot and now it has a very loose feel to it, like there used to be a sprign in it and now its broken. I can't shift into any gears so i had to drive my car all the way home in 1st gear. the only reason why i got my car started in the first place is because my car used to start without the clutch being engaged so i was lucky enugh to be able to start the car after this happened and drive it all the way home. i'm reading things like the slave cylinder but i would like to know what i could do to try and fix the problem in the cheapest possible way (ie. fluids) before resorting to the more expensive repairs. would changing the brake fluid be a potential way of fixing this problem?
Old Sep 9, 2007 | 07:36 PM
hiwords's Avatar
in ur case, changing the fluids won't do anything. since u have no leak it's either the cylinder or a pin on the clutch.
