Clutch Trouble
Old May 22, 2007 | 09:06 AM
mgp2001's Avatar
Default Clutch Trouble
Needing a new clutch for my A4, I purchased a Spec Stage II with an Aluminum single piece flywheel. Once installed and driven, I find that the transmission rattles a bit, but all else is acceptable. In an effort to silence this rattle a mechaninc suggests the installation of a snub-nose mount while replacing my timing belt. I agree, only to find out I now have a rattle and a high pitch squeal when first engaging the clutch. I argue but get no where. So I take it to another shop a few months later and tell them my story. The mechanic jumps in for a test drive and announces upon his return that the clutch is slipping, never mind the squeal. What? I check it out and, sure enough, it's slipping. Hmmmm. Clutch performance is better the next day, but not the same. It is still slipping, however, there is no squeal![/align][/align]So, I'm thinking this mechanic burnt my clutch out so he'd have some work. I really have no proof that this guy did anything wrong. I'm pretty sure I need to get it fixed and at least have the Spec techs look at it. Who ever does the job, I'll need a guarantee that the squeal won't return. What should I do?[/align][/align][/align]
Old May 22, 2007 | 09:53 AM
SacTown_Vlad's Avatar
Default RE: Clutch Trouble
Never heard of clutch causing squealing sound in transmission… and it’s not that easy to burn the clutch, I don’t think u can even burn Stage II clutch in few min. of test drive (u would have to be complete idiot and clutch would stink), most likely your clutch was already in a bad shape or it was very and very bad quality. You would have to take it off and see what’s wrong with it.
Wirral123
Oct 11, 2013 08:10 AM
Rdshepard80
Aug 20, 2013 05:20 AM
Rdshepard80
Aug 20, 2013 05:04 AM
a4audia4
Dec 16, 2012 12:11 PM
71custom
Oct 11, 2009 01:38 PM
