code in my car... problems!! more!!!
Old Mar 20, 2006 | 07:34 PM
audiguy00's Avatar
Default code in my car... problems!! more!!!
found a p0501 in my car. speed sensor something out of range/performance. anyone know the fix for this. my gas gauge is acting up. when on the throttle it goes to full when off it slams to empty. like a boost gauge. my info display is all lines and stuff. and i just can't figure out what to do. anyone know?
please help me!!!
bobby
i love this car its just turing out to be one big problem it has 95k on it.
Old Mar 20, 2006 | 11:44 PM
Slowb5's Avatar
Default RE: code in my car... problems!! more!!!
well dude, all i know is that jest posted a diy on how to fix a erratic fuel gauge problem...something w/ the sender in the gas tank...didnt look too hard to do.
1 problem down...as far as everything else..idk man.
Old Mar 21, 2006 | 01:28 AM
audiguy00's Avatar
alright another question just to be a pain again sorry bout all this guys... i know i'm dumb i just losing my mind with this car. anyway. has anyone run into any rear differential problems. when i get on and let off the gas it sounds like my rear is slamming or clunking. the whole car is jolting. just another question for ya's
thanks
bobby
Old Mar 21, 2006 | 01:56 AM
KevinBNH's Avatar
I have heard of stock rear springs letting go. mine did on my 98 a4 2.8 quattro. or maybe diff fluid. it could be many things. axle, wheel bearing susp bushing(s)......
Old Mar 21, 2006 | 02:06 AM
dan908's Avatar
Erratic speed sensor problem means you should clean your speed sensors in the wheels and if it does not fix then you have to replace them. It should be turning on the brake/ antilock light with the CEL.
Info display problem is common to Audi's I think ecartoys guy says it is a bad solder joint. Ok well i can't post his webpage but look for him he is a member.
If you do not know how to clean the wheel sensors, I post on it like once a week. Or you can find it in the Haynes manual.
Old Mar 21, 2006 | 02:08 AM
dan908's Avatar
Couldn't the thunk noise be the snub mount? that is what Jest told me to look to for a thunking when I backed out of my steep driveway... I disagreed although I know the snub mount would help the problem.
Old Mar 21, 2006 | 02:36 PM
audiguy00's Avatar
so you guys htink i should check my rear bushing and stuff. because it feels like my whole drive train is moving in the rear. like there is so much play... i just wish i knew where to start. becuase i think this could be some of my speedo problem because the one speed sensor sits right in the top of the rear diff. any other suggestions?
bobby
Old Mar 24, 2006 | 03:03 AM
KevinBNH's Avatar
I say put it on a lift or jack the back end up. try wigling the tire(s) back and forth and up and down. check the rear sway bar links too. You have to get under there to see where the problem is coming from.
Hove_06902
Jan 18, 2020 06:00 AM
barney12
Oct 20, 2019 03:30 AM
AudiHurts
Mar 6, 2015 04:41 PM
wayland
B7 Models
May 21, 2013 05:24 AM
quattroginger
Apr 17, 2013 07:09 AM
