Code P1128...help
Old Feb 28, 2007 | 02:47 PM
co50's Avatar
Default Code P1128...help
I have a 2000 A4 1.8T with a CEL burning a hole in my forehead. Code P1128 appears. What to do? I replaced the O2 sensor... still there... I pulled out my MAF sensor and it looks good... but how am I supposed to know if its bad.... is there a way to tell visually? Should I just spend the $50+ and buy a new? I did realize that the air filter was long overdue for a change. So I will replace that. But im sure a simple filter change wont get rid of the CEL.
Any help would be greatly appreciated.
Thanks in advance, Chris
Old Feb 28, 2007 | 03:03 PM
akielb's Avatar
Default RE: Code P1128...help
did you clear the code and it came back? or did you just repair everything and expect it to go away
Old Feb 28, 2007 | 03:04 PM
techbod's Avatar
your looking in the wrong area for a solution ( air leak )
[IMG]local://upfiles/12092/39CC53B2215F439E8474C5AE976E4784.jpg[/IMG]
Old Feb 28, 2007 | 03:27 PM
co50's Avatar
I actually had 3 codes and changed the O2.... cleared them... now i only have one code that came back.....which is the P1128...
and now for the hose leak??? how would i go about fixing that... finding the right hose(es) and then changing them (easy?) and of course how much $$.
thanks again for the help...
Old Feb 28, 2007 | 03:58 PM
onepoint8tee's Avatar
I bet the P1128 code is because of a bad MAF.
Old Feb 28, 2007 | 04:04 PM
techbod's Avatar
interesting theory there but only one problem ( the MAF is doing its job ) plus the MAF has its own code but not to say it isn't the MAF though,
check any hose/vacuum line for splits regardless of where they are
Old Feb 28, 2007 | 04:05 PM
co50's Avatar
is there a way i can test if the MAF is bad? or should i just replace it and cross my fingers?
Old Feb 28, 2007 | 04:10 PM
T28_A4's Avatar
what is your vacuum reading at idle inHG? If you have a vag-com look at your block 032 at idle and post the readings...to tell if the maf is bad, either do a wot run, in 2nd would be find and log your air mass in g/s...you can also tell by unplugging the maf, if the car still feels the same way when it is plugged in, = bad maf....could you list the codes that were cleared after you replaced the o2 sensor...your possibles are vac leak, maf, fuel filter... seems like from what you said, its a bad maf... how many miles on the car and what mods?
techbod's Avatar
[IMG]local://upfiles/12092/FE792ABC587C413BAC9D35FD5480B4FB.jpg[/IMG]
Old Feb 28, 2007 | 04:11 PM
co50's Avatar
i'll check the hoses and let you know what i come up with..
is there any trick in doing that ... or should i just look at them for obvious flaws/cracks?
