Code P1128...help
Old Feb 28, 2007 | 04:14 PM
T28_A4's Avatar
Default RE: Code P1128...help
to find a leak... http://www.a4mods.com/index.php?page...boostleak.html
Old Feb 28, 2007 | 04:15 PM
techbod's Avatar
obvious flaws/cracks is the best way and man handle them to see if they crumble
Old Feb 28, 2007 | 04:17 PM
techbod's Avatar
excellent link there T28-A4
Old Feb 28, 2007 | 04:28 PM
onepoint8tee's Avatar
ORIGINAL: T28_A4
what is your vacuum reading at idle inHG? If you have a vag-com look at your block 032 at idle and post the readings...to tell if the maf is bad, either do a wot run, in 2nd would be find and log your air mass in g/s...you can also tell by unplugging the maf, if the car still feels the same way when it is plugged in, = bad maf....could you list the codes that were cleared after you replaced the o2 sensor...your possibles are vac leak, maf, fuel filter... seems like from what you said, its a bad maf... how many miles on the car and what mods?
YUP! Probably a bad MAF.
Old Feb 28, 2007 | 04:32 PM
co50's Avatar
were the 3 codes.... P1128 was the only one that came back on after i cleared them.
65,000 miles .. no mods...
basically this is exactly what is going on....
when i start up the car the idol flutters up and down for about 8-10 seconds maybe 800 rpms. It then levels out…. It also sometimes does it when I come to a stop after driving. When I put gas in my car no matter if its 3 gallons to a full tank I have to pump the gas petal while cranking the ignition to get it started. Not sure whats up with that. Another fantastic thing that is going on is sometimes when I go around a corner or just simply going straight .. when the transmission miss-shifts…. Sometimes goes into neutral and revs…. Sometimes when I come to a stop it actually puts the car in reverse…. When I use the auto-stick (whatever its called) and manually use the paddles on the wheel to shift it doesn’t really seem to do it. Maybe its doing that because when I had the oil changed the idiots drained the transmission fluid instead… then had to put their crappy fluid in… because If I remember correctly that started around that time… but then again who knows. So those are the problems that are going on… .ugh
Old Feb 28, 2007 | 04:43 PM
Your car is posessed. Sell it asap. Strange stuff. I still think your MAF could be bad. It might be a vac leak though, I wouldnt rule it out. As far as the tranny goes, you better figure that one out asap.
Old Feb 28, 2007 | 04:46 PM
techbod's Avatar
I would class that as surging and a few things could cause that
[IMG]local://upfiles/12092/F37D76C5DFF94263A6F4B553EEFD8328.jpg[/IMG]
Old Feb 28, 2007 | 04:57 PM
  #18
techbod's Avatar
that code would lead me to the EVAP system for air leaks but just a guess
Old Feb 28, 2007 | 05:06 PM
  #19
co50's Avatar
well it looks like i have a lot of work to do....
thanks everyone for all of the imput. Keep postin if you have any other ideas.
i will see what i can figure out.
pwillaby
Jul 29, 2014 10:21 AM
mandito219
Jul 17, 2009 08:53 PM
BLK_A4
Mar 11, 2008 11:08 PM
gksboi329
Feb 16, 2008 05:21 PM
yhkimdc
Oct 10, 2007 02:51 PM
