Coil Pack, Easy to Install?
Old Aug 22, 2007 | 01:27 AM
03 Avant's Avatar
Default Coil Pack, Easy to Install?
03 Avant 3.0, started it up yesterday after work and cel popped up (kept flashing)and the car started to hesitate. I felt like it was running on 4cyl's. I made it home luckily. Who can tell me how they come off? I can see the clip connected to them, do you pop the clip to reveal bolts/screws underneath? I like to know if I can diy or drive it down to the mechanic. thx paul
Old Aug 22, 2007 | 03:03 AM
techbod's Avatar
Default RE: Coil Pack, Easy to Install?
6-cyl. 3.0 ltr. and 3.2 ltr. FSI engines
Switch off ignition.
Remove engine cover panel (if fitted) .
Cylinder bank (right-side)
Remove upper section of air cleaner .
Remove both bolts -1-.
Push connector -2- towards pencil-type ignition coil, press catch down by hand and pull off connector.
Use puller -T40039- to detach pencil-type ignition coils -3- from spark plugs.
Remove spark plugs using spark plug socket -T40039-.
Install new spark plugs.
Tightening torques
Nm
Spark plugs in cylinder head
30
Note[/align]
Press pencil-type ignition coils into the openings provided on the cylinder head cover by hand.
Cylinder bank (left-side)
Remove coolant expansion tank -arrow -.
Tie coolant expansion tank to one side with coolant hoses -1...3- attached.
[IMG]local://upfiles/12092/0E688C8FE0864876819C0C83A8610503.jpg[/IMG]
[IMG]local://upfiles/12092/1FC1C5AE3A644D088864760E1A93ED97.jpg[/IMG]
[IMG]local://upfiles/12092/D1F0E5BDEF58487A9162235B1137C94A.jpg[/IMG]
Old Aug 22, 2007 | 04:38 PM
03 Avant's Avatar
Thx again for the detailed intstructions, I just finished installing it. It cost $30 from dealer, 1hr , and one scratched nuckle. I didn't know which one was bad so I just started replacing one at a time and it turned out to be right front. I could tell that it might be that one, because it was harder to pull off and it had a burnt smell to it. My advice to others if you're going to diy, make sure you have the right sizestar bit for the screws holding down the wire loom. Just curious what would have been the labor rate to installthis at a service shop or dealership. My back is just not as flexible as it used to be.
Old Aug 22, 2007 | 07:20 PM
tdn's Avatar
tdn
You wouldn't happen to have the instructions for a 2001 1.8t.. or is it pretty much the same?
I think I know what I'm doing, but directions would help a lot and possibly prevent me from messing up my car.
Old Aug 23, 2007 | 03:19 PM
widgget's Avatar
the 1.8 is so easy, pop the engine cover and pull the coil out, unplug it, put a new one in and your done. you shoudl do the plugs at the same time though. i have a full set of spares in my trunk at all times.
Old Aug 23, 2007 | 03:30 PM
techbod's Avatar
even easier on the 4 cylinder engine as wigget says,
edit: missed the important bit lol
4-cyl. 5V engines (turbocharged):
Remove engine cover panel.
With the ignition switched off, disconnect the connectors from the ignition coils.
Unscrew and remove the ignition coils -arrows-.
Remove spark plugs using spark plug socket -3122B-.
Install ignition coils. Renew seals if damaged.
[IMG]local://upfiles/12092/B21F04614953495CA1A9A1C34FD529A0.jpg[/IMG]
Old Aug 23, 2007 | 03:44 PM
ee99ee's Avatar
yes, 4-cyl is VERY easy....
Old Aug 23, 2007 | 04:06 PM
tdn's Avatar
tdn
Figures I ask the ridiculously easy questions. Oh well, you all are always a great help.
Old Aug 23, 2007 | 04:13 PM
techbod's Avatar
personally its not a ridiculous question by any means the engine bay can look like a very clean area with all that covers it so the obvious is not always easy to see unless you have done it before but now your learning DIY so its worth the answers
Nov 20, 2010 03:40 PM
soltisb
Jul 13, 2010 03:54 PM
kraylon
Jul 29, 2009 12:19 AM
AudiATX
Sep 9, 2008 10:12 AM
McGuireDennis
Dec 13, 2006 12:53 PM
