Trying this again - Help with '98 A4 V6 coil pack install
Old Jul 12, 2010 | 07:34 PM
soltisb's Avatar
Default Trying this again - Help with '98 A4 V6 coil pack install
I posted this a couple months ago looking for help and no one replied. I just received a new coil pack in the mail and need help with installation.
Could anyone who has experience/knowledge of this sort of thing offer instructions on how to remove the old coil pack and replace it with a new one?
Thank you kindly,
B. James
Old Jul 12, 2010 | 08:50 PM
chocalotstarfish's Avatar
Super Moderator
It's really easy, remove engine covers just pull out coilpacks unplug from the side and replace! Some models have the coilpacks held in by 5mm allens.
Old Jul 12, 2010 | 11:11 PM
Nevalite's Avatar
Just like chcolat said. It's like changing your spark plugs, just you change the coil pack instead of the spark plug :P
Here is a guide for spark plugs to get you going. Guide You're following the same steps but instead of changing your spark plugs you're replacing those big funny things you take out of the engine.
Old Jul 13, 2010 | 03:13 PM
ImTheDevil's Avatar
Guys - he has a V6. It's completely different than yours. You have coil on plug setups but the V6 has a coil bank at the top front of the engine, with wires leading to each plug.
To the OP - unbolt the coil bracket that secures the coils. Mark each wire in some way before undoing it so that you put it back correctly on the new coil pack. Disconnect the harnesses on the pack and remove it. Install the new one in the reverse order.
Old Jul 13, 2010 | 03:54 PM
Nevalite's Avatar
I clearly missed that, my bad lol.
Nov 20, 2010 03:40 PM
kraylon
Jul 29, 2009 12:19 AM
AudiATX
Sep 9, 2008 10:12 AM
03 Avant
Aug 23, 2007 04:13 PM
McGuireDennis
Dec 13, 2006 12:53 PM
