Cold induction and DV question
i have a 2002 1.8t (163)
i want to add a cold air intake system withous messin up the MAF, any alternatives?, i heard filter like k and n clog up the maf from the oil,
will a DV and induction change the acoustics in any way?
i want to push 180ps without any chipping any suggestions??
Get a K&N, just was off the factory oil (there isn't much) with dish soap befor you use it and you'll be fine. Also changing the Air filter and DV (both are good to do) will not change the acoustics.
So you want 30hp extra.
-DV
-K&N in stock box
-Cat-Back
-3" Cat delete pipe
-N75 J
Clean your maf, throtle plate,intercooler
These should give you some extra power for sure.
-DV
-K&N in stock box
-Cat-Back
-3" Cat delete pipe
-N75 J
induction kits
Jun 20, 2004 12:39 AM
