Complete car noob here - O2 sensor issue
Old Sep 17, 2007 | 02:07 PM
onepoint8tee's Avatar
Default RE: Complete car noob here - O2 sensor issue
ORIGINAL: avant80@2.6
what OBD system did he use? what was the code? only reason im asking is the 2003 car needs to be scanned with CAN bus ( VAG-HEX ) not the old OBD II
Stores (at least around here) like autozone have the Hex adapter that works with ODBII scanners.
Old Sep 17, 2007 | 02:14 PM
techbod's Avatar
that's good to know normally they just guess when they dont have the right tool thats why I asked for the code
Old Sep 17, 2007 | 02:26 PM
goldark's Avatar
I couldn't help myself and skipped out of work a little to see the mechanic. It said "Bank 1 Oxygen Sensor."
What does this refer to?
Old Sep 17, 2007 | 02:33 PM
After it says "Bank 1" it should say "S1" or "S2" meaning 1st sensor (precat) or S2 2nd (post cat) sensor.
Old Sep 17, 2007 | 02:37 PM
techbod's Avatar
that's the O2 sensor but if you had the code it would tell me if that was the problem or if it were an air/vacuum leak which was causing the O2 sensor to give a bad reading P1131 is the O2 sensor bank 1 sensor 1 now if it were that code it would be wiring and most likely the O2 sensor but saying that there are a few codes that say the O2 sensor when its not that causing the problem if you see what I mean
infernomachine
Sep 16, 2014 11:55 AM
ahamoil
Mar 3, 2008 01:47 AM
fantius
Sep 26, 2007 12:33 AM
lilredwagon
Jul 19, 2007 11:51 PM
