Computer
I was having problems with acceration, so i took it to the mech and they told me it was low on Tranny fluid, i changed that and it still had the same thing, took in again and they told me it was the #3 cylinder and they told me to replace the ignition coil so i did and the problem persisted. I took it to European Auto they did a diagonosis and they told me that my compression was good but my #3 was mis firing so they said remove the plugs and put NGK's so i did and still had the issues, took it to another Mech and they said it was the Computer and thats where am stuck at. F***k,,,,, 500 dollars later i feel like i want to throw away the damm car. Damm if this cars did not look so damm good and drive so damm smooth i would park under a tree.
Had those wires checked from front to end and they were not the problem. He has done some good work on my other cars before, i do believe he's real through and through with making sure that was not the issue. What is ICM[&:]
