Computer
Old Apr 5, 2006 | 06:44 PM
manzi's Avatar
Default Computer
Does anyone have a computer that i could buy for a 1997 1.8t.
Thanks
Old Apr 5, 2006 | 06:51 PM
tip5's Avatar
Default RE: Computer
A computer? Or an ecu?
Old Apr 5, 2006 | 06:54 PM
manzi's Avatar
Looking for the computer!!!
Old Apr 5, 2006 | 06:57 PM
aRIf's Avatar
I have one PIII 550, 512bm ram, 40gb hdd
I am not sure if it works with you 97 1.8t
Old Apr 5, 2006 | 07:00 PM
manzi's Avatar
Am not sure which is the problem though i have a # for the computer 8D0907559 does any of this #'s match.
Old Apr 5, 2006 | 07:03 PM
aRIf's Avatar
listen tip5, he is right. You need a ECU which you can call computer.
you can find used one for $300-$400 I think... there was a site selling them but not sure...
Old Apr 5, 2006 | 07:04 PM
aRIf's Avatar
It will be easier if you tell us what it wrong with your car.
Old Apr 5, 2006 | 07:08 PM
manzi's Avatar
Default Here Goes
I was having problems with acceration, so i took it to the mech and they told me it was low on Tranny fluid, i changed that and it still had the same thing, took in again and they told me it was the #3 cylinder and they told me to replace the ignition coil so i did and the problem persisted. I took it to European Auto they did a diagonosis and they told me that my compression was good but my #3 was mis firing so they said remove the plugs and put NGK's so i did and still had the issues, took it to another Mech and they said it was the Computer and thats where am stuck at. F***k,,,,, 500 dollars later i feel like i want to throw away the damm car. Damm if this cars did not look so damm good and drive so damm smooth i would park under a tree.
Old Apr 5, 2006 | 07:17 PM
onepoint8tee's Avatar
Default RE: Here Goes
ICM?
Coil pack wiring/connection?
Old Apr 5, 2006 | 07:20 PM
manzi's Avatar
Had those wires checked from front to end and they were not the problem. He has done some good work on my other cars before, i do believe he's real through and through with making sure that was not the issue. What is ICM[&:]
